On automating networked enterprise management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Ustun Yildiz
  • Fonction : Auteur
  • PersonId : 830461
Olivier Perrin
  • Fonction : Auteur
  • PersonId : 755677
  • IdRef : 171122291
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
With the new middleware IT technologies such as Web Services and peer-to-peer computing facilities, a Virtual Enterprise can be built easier achieving some problems of interoperability. Although existing standards deal with syntactic issues they are primitive for the maintenance of VE while the processes are fulfilled in the untrusted and dynamic environment of the Web. In this paper, we investigate the problems of maintenance and propose a generic model that can be used for the automation purposes of monitoring and management. The mechanism we propose models the process of the Virtual Enterprise and the perspective of process manager. Thus, it automates the maintenance according to predefined configurations.
On_automating_virtual_enterprise.pdf (121.88 Ko) Télécharger le fichier
inria-00000229 , version 1 (16-09-2005)
Ustun Yildiz, Olivier Perrin, Claude Godart. On automating networked enterprise management. International Workshop on Enterprise and Networked Enterprises Interoperability - ENEI'2005, Sep 2005, Nancy/France, pp.363-374, ⟨10.1007/11678564_32⟩. ⟨inria-00000229⟩
81 Consultations
231 Téléchargements
