Customizable Isolation in Transactional Workflow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Adnene Guabtni
  • Fonction : Auteur
  • PersonId : 830150
François Charoy
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
In Workflow Management Systems (WFMSs) safety of execution is a main need of more and more business processes and transactional workflows are real needs inside enterprizes. In previous works, transactional models consider mainly atomicity as the main issue regarding long term transactions. It rarely consider the fact that many processes may run concurrently and thus access and update the same data. Usually, the main isolation item is the data on which we apply locking approaches and this attitude don't worry about process dimension. In this work we study more precisely what are the real isolation needs in workflow environment. To realize these needs, we define "Isolation Spheres" inspired from "spheres of control" proposed by C. T. Davies to make a separation of concerns between workflow design and transactional properties specification.
ESA2005.pdf (126.91 Ko) Télécharger le fichier
inria-00000243 , version 1 (16-09-2005)
  • HAL Id : inria-00000243 , version 1
Adnene Guabtni, François Charoy, Claude Godart. Customizable Isolation in Transactional Workflow. First International Conference on Interoperability of Enterprise Software and Applications - INTEROP-ESA'2005, University of Geneva, Switzerland, Feb 2005, Geneva/Switzerland, pp.197-202. ⟨inria-00000243⟩
92 Consultations
173 Téléchargements
