Spheres of isolation: adaptation of isolation levels to transactional workflow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Adnene Guabtni
  • Fonction : Auteur
  • PersonId : 830150
François Charoy
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
In Workflow Management Systems (WFMSs), transaction isolation is managed most of the time by the underlying database system using ANSI SQL strategies. These strategies do not take sufficiently into account process aspects. Our work consists in studying with more depth the relation between isolation strategy and process dimension as well as the real isolation needs in workflow environments. To carry out these needs, we define `spheres of isolation' inspired from `spheres of control' proposed by C. T. Davies. Spheres of isolation take into account real workflow isolation needs with separation of concerns between workflow design and the specification of its transactional properties.
Guabtni-BPM2005.pdf (74.18 Ko) Télécharger le fichier
inria-00000246 , version 1 (19-09-2005)
Adnene Guabtni, François Charoy, Claude Godart. Spheres of isolation: adaptation of isolation levels to transactional workflow. Third International Conference on Business Process Management - BPM'2005, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications, Sep 2005, Nancy/France, pp. 458 - 463, ⟨10.1007/11538394⟩. ⟨inria-00000246⟩
62 Consultations
308 Téléchargements
