Abstract : This paper presents a network management framework for an auto-configuration of dynamic networks using Web Services. The example of VPN configuration is used as a proof of concept, and the Active XML technology provides the underlying Web Services technology with a Peer2Peer infrastructure. We present those technologies applied to network management as well as our prototype implementation, and we discuss the pros and cons of our solution and our future work.
Laurent Ciarletta, Mi-Jung Choi. Automatic configuration for VPN using Active XML. 5th International Workshop on IP Operations & Management - IPOM 2005, Oct 2005, Barcelona/Spain, pp.173--180. ⟨inria-00000422⟩
