A low-cost stereovision based system for acquisition of visible articulatory data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In this paper, we present the 3D acquisition infrastructure we developed for building a talking face and studying some aspects of visual speech. A short-term aim is to study coarticulation for the French language and to develop a model which respects a real talker articulation. One key factor is to be able to acquire a large amount of 3D data with a low-cost system more flexible than existing motion capture systems (using infrared cameras and glued markers). Our system only uses two standard cameras, a PC and painted markers that do not change speech articulation and provides a sufficiently fast acquisition rate to enable an efficient temporal tracking of 3D points. We present here our stereovision data capture system and how these data can be used in acoustic-to-articulatory inversion
avsp.pdf (1.65 Mo) Télécharger le fichier
inria-00000432 , version 1 (13-10-2005)
  • HAL Id : inria-00000432 , version 1
Brigitte Wrobel-Dautcourt, Marie-Odile Berger, Blaise Potard, Yves Laprie, Slim Ouni. A low-cost stereovision based system for acquisition of visible articulatory data. 5th Conference on Auditory-Visual Speech Processing - AVSP'2005, Jul 2005, Vancouver Island (BC), Canada. ⟨inria-00000432⟩
255 Consultations
145 Téléchargements
