Matchmaking in Heterogeneous Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Dong Cheng
  • Fonction : Auteur
  • PersonId : 830687
In more and more service domains, composite services will be necessary, as application ranging from search engines (such as Google, Yahoo, etc.), to more general applications, like cooperative and distributed applications or e-business and e-commerce applications. In a lot of situations, the usable information is recorded by different persons, at different times, in different languages, on different fields. The composite service programme must have the capability to process the heterogeneous information. In this paper we focus on the problem of mismatch in knowledge representation languages. Specifically, we have implemented a matchmaking service in a homogeneous knowledge representation environment (using Description Logics). Based on this experience we show an approach for measuring mismatch in an heterogeneous knowledge representation environment.
Fichier non déposé
inria-00000437 , version 1 (14-10-2005)
  • HAL Id : inria-00000437 , version 1
Dong Cheng. Matchmaking in Heterogeneous Environments. Doctoral symposium in INTEROP-ESA'05 - First International Conference on Interoperability of Enterprise Software and Applications, INTEROP, Feb 2005, Geneva/ Switzerland. ⟨inria-00000437⟩
49 Consultations
0 Téléchargements
