Modelling SystemC scheduler by refinement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Systems on Chip, or shortly SoCs, and SoC architectures denote a challenging set of problems of specification, modelling techniques, security issues and structuring questions. Our methodology, for designing models of (SoC) system from requirements, leads to formally justify hints on the future architectural choices of that system; it is based on the B event-based method, which integrates the incremental development of models using a theorem prover to validate each step of development called refinement. The target system is generally expressed using a programming language notation like SystemC; the SystemC language is used by electronic designers to describe different parts of the system (hardware and software); SystemC constitutes a general framework for simulating and validating the design of the system under construction. The semantics of SystemC is based on its scheduling algorithm described in the language reference manual and we develop a B model of the scheduling. The B \textit{scheduling} model left unspecified parameters depending on the simulated SystemC program and those parameters are instantiated from the operational semantics of the developed SystemC program. By instantiation, we obtain a B abstract model of the simulated program and we can study properties of the SystemC program by simulation. B models are completely validated by the proof assistant of the event-B method. Finally, our models provide a sound framework for understanding the scheduling process.
cansellmeryprochisola2005.pdf (186.01 Ko) Télécharger le fichier
inria-00000564 , version 1 (03-11-2005)
  • HAL Id : inria-00000564 , version 1
Dominique Cansell, Dominique Méry, Cyril Proch. Modelling SystemC scheduler by refinement. IEEE ISoLA Workshop on Leveraging Applications of Formal Methods, Verification, and Validation - ISOLA'05, Sep 2005, Columbia/USA. ⟨inria-00000564⟩
159 Consultations
312 Téléchargements
