A Statistical Approach for Geometric Smoothing of Discrete Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In this article we propose an original method for discrete surface smoothing. This method is based on a statistical estimation of the discrete tangent plane on the voxels of the discrete surface. A geometrical constraint is used to control the recognition of the tangent plane. The resulting surface representation allows us to get both smooth normal vectors of the surface and a smooth surface mesh while preserving the geometrical properties of the surface.
Fichier non déposé
inria-00000745 , version 1 (18-11-2005)
  • HAL Id : inria-00000745 , version 1
Bertrand Kerautret, Achille Braquelaire. A Statistical Approach for Geometric Smoothing of Discrete Surfaces. International Conference on Discrete Geometry for Computer Imagery, Apr 2005, Poitiers, France, pp.405-414. ⟨inria-00000745⟩
Collections
CNRS
61 Consultations
0 Téléchargements
