New interface
Journal articles
Reconstruction of Lambertian Surfaces by Discrete Equal Height Contours and Regions Propagation
Abstract : This paper describes two new methods for the reconstruction of discrete surfaces from shading images. Both approaches are based on the reconstruction of a discrete surface by mixing photometric and geometric techniques. The processing of photometric informations is based on reflectance maps which are classic tools of shape from shading. The geometric features are extracted from the discrete surface and propagated along the surface. The propagation is based in one case on equal height discrete contour propagation and in the other case on region propagation. Both methods allow photometric stereo. Results of reconstruction from synthetic and real images are presented.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00000746
Contributor : Bertrand Kerautret Connect in order to contact the contributor
Submitted on : Friday, November 18, 2005 - 2:19:04 AM
Last modification on : Saturday, June 25, 2022 - 10:29:52 AM
Links full text
Identifiers
Collections
Citation
Achille Braquelaire, Bertrand Kerautret. Reconstruction of Lambertian Surfaces by Discrete Equal Height Contours and Regions Propagation. Image and Vision Computing, 2005, 23 (2), pp.177-189. ⟨10.1016/j.imavis.2004.06.006⟩. ⟨inria-00000746⟩
Share
Metrics
Record views
104
