Decidable Type Inference for the Polymorphic Rewriting Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The rewriting calculus is a minimal framework embedding lambda calculus and term rewriting systems that allows abstraction on variables and patterns. The rewriting calculus features higher-order functions (from the lambda calculus) and pattern matching (from term rewriting systems). In this paper, we study extensively the decidability of type inference in the second-order rewriting calculus à la Curry.
cirstea.pdf (292.08 Ko) Télécharger le fichier
inria-00000817 , version 1 (12-12-2005)
  • HAL Id : inria-00000817 , version 1
Horatiu Cirstea, Claude Kirchner, Luigi Liquori, Benjamin Wack. Decidable Type Inference for the Polymorphic Rewriting Calculus. 17è Journées Francophones des Langages Applicatifs - JFLA 2006, Jan 2006, Pauillac, France. pp.57-69. ⟨inria-00000817⟩
187 Consultations
91 Téléchargements
