Modular Formal Islands: Embed theory in your practice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Motivated by the proliferation and usefulness of Domain Specific Languages as well as the demand in enriching well established languages by high level capabilities like modularity, pattern matching or strategic rewriting, we have introduced in previous works the Formal Islands framework. The main idea consists in integrating, in existing programs, formally defined parts called Islands, on which proofs and tests can be meaningfully developed. Then, Formal Islands could be safely dissolved into their hosting language to be transparently integrated in the existing user environment. We present this generic framework and we show that language extensions like Mhtml—providing modular constructions for html— or Tom—a Java language extension allowing for pattern matching and rewriting—are indeed Islands and can therefore be used to embed formal software developments into legacy code.
tfit06.pdf (246.87 Ko) Télécharger le fichier
inria-00001186 , version 1 (31-03-2006)
  • HAL Id : inria-00001186 , version 1
Emilie Balland, Claude Kirchner, Pierre-Etienne Moreau, Anderson Santana de Oliveira. Modular Formal Islands: Embed theory in your practice. Third Taiwanese-French Conference on Information Technology - TFIT 2006, INRIA/LORIA, Mar 2006, Nancy/France. ⟨inria-00001186⟩
106 Consultations
115 Téléchargements
