Using both Derivation tree and Derived tree to get dependency graph in derivation forest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
The aim of this paper is to describe an approach to syntaxico-semantic representation in the Lexicalized Tree Adjoining Grammars (LTAG) paradigm \cite{jos:97}. We show that it is possible to use both LTAG's derived and derivation trees, through a shared forest, to build a dependency graph as a basis for further semantic calculation. We illustrate this method with problems raised by control verbs. We assume that the reader is familiar with the LTAG formalism and its operations
Fichier non déposé
inria-00001199 , version 1 (04-04-2006)
  • HAL Id : inria-00001199 , version 1
Djamé Seddah, Bertrand Gaiffe. Using both Derivation tree and Derived tree to get dependency graph in derivation forest. 6th International Workshop on Computational Semantics - IWCS-6, Jan 2005, Tilburg/Pays-Bas. ⟨inria-00001199⟩
38 Consultations
0 Téléchargements
