MODERES Java: Architecture and Core Packages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 1997
MODERES is an environment for the development of management information models. The initial release of the environment was developped in C++ and provided tools for the manipulation of information models specified using GDMO and GRM. This report presents the architecture and core packages of the MODERES Java environement. This environement is completely developped in Java and contains the initial MODERES tools as well as a new architecture for the use of the MODERES suite in an enterprise network.
Mots clés
Autre [cs.OH]
RT-0205.pdf (210.17 Ko) Télécharger le fichier
inria-00069966 , version 1 (19-05-2006)
  • HAL Id : inria-00069966 , version 1
Olivier Festor. MODERES Java: Architecture and Core Packages. [Technical Report] RT-0205, INRIA. 1997, pp.18. ⟨inria-00069966⟩
67 Consultations
94 Téléchargements
