HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
A Decision Procedure for XPath Containment
Pierre Genevès 1 Nabil Layaïda 1
1 WAM - Web, adaptation and multimedia
Inria Grenoble - Rhône-Alpes
Abstract : XPath is the standard language for addressing parts of an XML document. We present a sound and complete decision procedure for containment of XPath queries. The considered XPath fragment covers most of the language features used in practice. Specifically, we show how XPath queries can be translated into equivalent formulas in monadic second-order logic. Using this translation, we construct an optimized logical formulation of the containment problem, which is decided using tree automata. When the containment relation does not hold between two XPath expressions, a counter-example XML tree is generated. We provide a complexity analysis together with practical experiments that illustrate the efficiency of the decision procedure for realistic scenarios.
Document type :
Reports
Complete list of metadata
Cited literature [45 references]  Display  Hide  Download
https://hal.inria.fr/inria-00070159
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 7:17:03 PM
Last modification on : Wednesday, April 6, 2022 - 3:48:02 PM
Long-term archiving on: : Tuesday, February 22, 2011 - 11:37:01 AM
Identifiers
  • HAL Id : inria-00070159, version 1
Collections
Citation
Pierre Genevès, Nabil Layaïda. A Decision Procedure for XPath Containment. [Research Report] RR-5867, INRIA. 2006, pp.41. ⟨inria-00070159⟩
Share
Metrics
Record views
109
Files downloads
93
