Abstract : Anti-collision radars help prevent car accidents by detecting obstacles in front of vehicles equipped with such systems. This task traditionally relies on a correlator, which searches for similarities between an emitted and a received wave. Other modules can then use the information produced by the correlator to compute the distance and the relative speed between the moving vehicle and the obstacle. We implemented such a system using FPGA. We used hardware blocks to implement the high demanding computing correlator and a soft-core processor to compute the distances and speeds. In order to improve the maximum detection distance reached by the correlation algorithm, we developed and tested a modified version of a Higher Order Statistics based algorithm. This work results in a detailed description of this new algorithm, its possible implementations and their FPGA synthesis results.
https://hal.inria.fr/inria-00070205
Contributor : Rapport de Recherche Inria <>
Submitted on : Friday, May 19, 2006 - 7:29:44 PM Last modification on : Thursday, February 21, 2019 - 10:52:49 AM Long-term archiving on: : Sunday, April 4, 2010 - 8:34:34 PM
Sébastien Le Beux, Vincent Gagné, El Mostapha Aboulhamid, Philippe Marquet, Jean-Luc Dekeyser. Hardware/Software Exploration for an Anti-collision Radar System. [Research Report] RR-5820, INRIA. 2006, pp.15. ⟨inria-00070205⟩
