On the use of unfoldings to abstract communicating automata into sets of scenarios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We consider the problem of automatic abstraction, from a low-level model given in term of network of interacting automata to a high-level message sequence chart. This allows the designer to play in a coherent way with the local and global views of a system, and opens new perspectives in reverse model engineering of concurrent systems. Our technique is based on a partial order semantics of synchronous parallel automata and the construction of a complete finite prefix of an event-structure coding all the behaviors. We present the models and algorithms. The examples presented in the report have been processed by a small software prototype we have implemented.
Autre [cs.OH]
RR-5778.pdf (670.54 Ko) Télécharger le fichier
inria-00070243 , version 1 (19-05-2006)
  • HAL Id : inria-00070243 , version 1
Thomas Chatain, Loïc Hélouët, Claude Jard. On the use of unfoldings to abstract communicating automata into sets of scenarios. [Research Report] RR-5778, INRIA. 2005, pp.23. ⟨inria-00070243⟩
135 Consultations
65 Téléchargements
