HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Dassflow :a Direct and Adjoint model for 2D Shallow Water flows
Marc Honnorat 1 François-Xavier Le Dimet Youssef Loukili Jerome Monnier
1 IDOPT - System identification and optimization in physics and environment
Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : UMR5527
Abstract : The Dassflow software is designed to solve the bidimensional Shallow Water equations used for the numerical modeling of river hydraulics flows. It was written to carry out variational data assimilation experiments. Based on a finite volume discretization of the Shallow Water equations, the code is written in Fortran 90. The adjoint code necessary to compute the partial derivatives of a cost function of the state variables w.r.t. the control variables of the model was developed using the automatic differentiation tool Tapenade. We present the considered equations, the theoretical bases of variational data assimilation, the numerical scheme used for solving the equations as well as the implementation of the adjoint code. Finally, we present twin experiments of data assimilation performed with Dassflow.
Document type :
Reports
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/inria-00070264
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 7:46:50 PM
Last modification on : Friday, February 4, 2022 - 3:10:41 AM
Long-term archiving on: : Sunday, April 4, 2010 - 8:46:34 PM
Identifiers
  • HAL Id : inria-00070264, version 1
Collections
Citation
Marc Honnorat, François-Xavier Le Dimet, Youssef Loukili, Jerome Monnier. Dassflow :a Direct and Adjoint model for 2D Shallow Water flows. RR-5756, INRIA. 2005, pp.21. ⟨inria-00070264⟩
Share
Metrics
Record views
573
Files downloads
1044
