An Algebraic Attack against Augot-Finiasz Cryptosystem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We design an efficient probabilistic attack against the Augot-Finiasz cryptosystem presented at Eurocrypt 2003 enabling an attacker to recover the plaintext of the transmission if one uses the way to reduce the size of the public-key as suggested by the authors. To achieve this we use simple algebraic tools such as the Trace operator. The attacks succeeds in less than 5 minutes on the original parameters.
Autre [cs.OH]
RR-5662.pdf (232.27 Ko) Télécharger le fichier
inria-00070346 , version 1 (19-05-2006)
  • HAL Id : inria-00070346 , version 1
Pierre Loidreau. An Algebraic Attack against Augot-Finiasz Cryptosystem. [Research Report] RR-5662, INRIA. 2005, pp.13. ⟨inria-00070346⟩
67 Consultations
95 Téléchargements
