Simplifying Polynomial Expressions in a Proof Assistant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Laurent Théry
This paper presents a simple way of performing polynomial simplifications in a proof assistant. This method has been implemented and tested within the Coq prover.
Autre [cs.OH]
RR-5614.pdf (240.91 Ko) Télécharger le fichier
inria-00070394 , version 1 (19-05-2006)
  • HAL Id : inria-00070394 , version 1
Laurent Théry. Simplifying Polynomial Expressions in a Proof Assistant. [Research Report] RR-5614, INRIA. 2005, pp.16. ⟨inria-00070394⟩
134 Consultations
203 Téléchargements
