Analysis of Jansen's model of a single cortical column - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this report we present a mathematical analysis of a simple model of a cortical column. We first recall some known biological facts about cortical columns. We then present a mathematical model of such a column, developed by a number of people including Lopes Da Silva, Jansen, Rit. Finally we analyze some aspects of its behaviour in the framework of the theory of dynamical systems using bifurcation theory and the software package XPP-Aut developed by B. Ermentrout. This mathematical approach leads us to a compact representation of the model that allows to finally discuss its adequacy with biology.
Autre [cs.OH]
RR-5597.pdf (654.06 Ko) Télécharger le fichier
inria-00070410 , version 1 (19-05-2006)
  • HAL Id : inria-00070410 , version 1
François Grimbert, Olivier Faugeras. Analysis of Jansen's model of a single cortical column. [Research Report] RR-5597, INRIA. 2006, pp.34. ⟨inria-00070410⟩
378 Consultations
1612 Téléchargements
