HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Data Handover: Reconciling Message Passing and Shared Memory
Jens Gustedt 1
1 ALGORILLE - Algorithms for the Grid
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : We present a programming paradigm and interface that aims to handle data between parallel or distributed processes that mixes aspects of message passing and shared memory. It is designed to overcome the potential problems in terms of efficiency of both: memory blow up and forced copies for message passing and
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00070620
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 9:02:03 PM
Last modification on : Friday, February 26, 2021 - 3:28:02 PM
Long-term archiving on: : Sunday, April 4, 2010 - 9:35:39 PM
Identifiers
  • HAL Id : inria-00070620, version 1
Collections
Citation
Jens Gustedt. Data Handover: Reconciling Message Passing and Shared Memory. [Research Report] RR-5383, INRIA. 2004, pp.17. ⟨inria-00070620⟩
Share
Metrics
Record views
56
Files downloads
121
