Self-Organization in Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Nathalie Mitton
Anthony Busson
Eric Fleury
Flat ad hoc architectures are not scalable. In order to overcome this major drawback, hierarchical routing is introduced since it is found to be more effective. The main challenge in hierarchical routing is to group nodes into clusters. Each cluster is represented by its cluster head. Most of conventional methods use either the connectivity (degree) or the node Id to perform the cluster-head election. Such parameters are not really robust in terms of side effects. In this paper we introduce a novel measure that both forms clusters and performs the cluster-head election. Analytical models and simulation results show that this new measure proposed for cluster-head election induces less cluster-head changes as compared to classical methods.
Autre [cs.OH]
RR-5328.pdf (1.09 Mo) Télécharger le fichier
inria-00070672 , version 1 (19-05-2006)
  • HAL Id : inria-00070672 , version 1
Nathalie Mitton, Anthony Busson, Eric Fleury. Self-Organization in Ad Hoc Networks. [Research Report] RR-5328, INRIA. 2004, pp.41. ⟨inria-00070672⟩
146 Consultations
61 Téléchargements
