A floating-point library for integer processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
This paper presents a C library for the software support of single precision floating-point (FP) arithmetic on processors without FP hardware units such as VLIW or DSP processor cores for embedded applications. This library provides several levels of compliance to the IEEE 754 FP standard. The complete specifications of the standard can be used or just some relaxed characteristics such as restricted rounding modes or computations without denormal numbers. This library is evaluated on the ST200 VLIW processors from STMicroelectronics.
RR-5268.pdf (285.71 Ko) Télécharger le fichier
inria-00070730 , version 1 (19-05-2006)
  • HAL Id : inria-00070730 , version 1
C. Bertin, Nicolas Brisebarre, Benoît de Dinechin, Claude-Pierre Jeannerod, C. Monat, et al.. A floating-point library for integer processors. [Research Report] RR-5268, INRIA. 2004, pp.17. ⟨inria-00070730⟩
147 Consultations
497 Téléchargements
