HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Homogenization approach to filtration through a fibrous medium
Mohamed Belhadj 1 Eric Cancès 2 Jean-Frédéric Gerbeau 3 Andro Mikelic
1 BANG - Nonlinear Analysis for Biology and Geophysical flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt
2 MICMAC - Methods and engineering of multiscale computing from atom to continuum
Inria Paris-Rocquencourt, ENPC - École des Ponts ParisTech
3 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : We study the flow through fibrous media using homogenization techniques. The fiber network under study is the one already used by M. Briane in the context of heat conduction of biological tissues. We derive and justify the effective Darcy equation and the permeability tensor for such fibrous media. The theoretical results on the permeability are illustrated by some numerical simulations. Finally, the low solid fraction limit is considered. Applying results by G. Allaire to our setting, we justify rigorously the leading order term in the empirical formulas for the effective permeability used in engineering. The results are also confirmed by a direct numerical calculation of the permeability, in which the small diameter of the fibers requires high accuracy approximations.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071254
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 2:53:25 PM
Last modification on : Friday, January 21, 2022 - 3:21:19 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:04:52 PM
Identifiers
  • HAL Id : inria-00071254, version 1
Citation
Mohamed Belhadj, Eric Cancès, Jean-Frédéric Gerbeau, Andro Mikelic. Homogenization approach to filtration through a fibrous medium. [Research Report] RR-5277, INRIA. 2004. ⟨inria-00071254⟩
Share
Metrics
Record views
245
Files downloads
293
