New interface
Reports (Research report)
Complexity results and heuristics for pipelined multicast operations on heterogeneous platforms
Olivier Beaumont 1 Arnaud Legrand 1 Loris Marchal 1 Yves Robert 1
1 REMAP - Regularity and massive parallel computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : In this paper, we consider the communications involved by the execution of a complex application deployed on a heterogeneous platform. Such applications extensively use macro-communication schemes, for example to broadcast data items to several targets, known as the multicast operation. Rather than seeking to minimize the execution time of a single multicast, we focus on steady-state performance. We target heterogeneous platforms, modeled by a graph where resources have different communication speeds. We show that the problem of computing the best throughput for a multicast operation is NP-hard, whereas the best throughput to broadcast a message to every node in a graph can be computed in polynomial time. Thus we introduce several heuristics to deal with this problem; most of them are based on linear programming. We prove that some of these heuristics are approximation algorithms. We perform simulations to test these heuristics and show that their results are close to a theoretical upper bound on the throughput that we obtain with the linear programming approach.
Document type :
Complete list of metadata
Cited literature [40 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071460
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 5:36:47 PM
Last modification on : Wednesday, October 26, 2022 - 8:14:15 AM
Identifiers
  • HAL Id : inria-00071460, version 1
Collections
Citation
Olivier Beaumont, Arnaud Legrand, Loris Marchal, Yves Robert. Complexity results and heuristics for pipelined multicast operations on heterogeneous platforms. [Research Report] RR-5123, LIP RR-2004-07, INRIA, LIP. 2004. ⟨inria-00071460⟩
Share
Metrics
Record views
82
Files downloads
242
