Building a JMX management interface inside OSGi - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Stéphane Frénot
The «pervasive computing» will allow users to be able to utilize various applications through functional objects anytime and anywhere. Since pervasive computing is intrinsically highly dynamic and heterogeneous, applications should becomes «context-dependent » and able to change their functionality depending on dynamically changing user context. In a pervasive computing context, one must pay attention to the management part, inherent to the service deployment process. A automatic way to instrument and allow remote management control of distributed services becomes mandatory. This paper describes a supervising architecture for service oriented application in order to design and deploy context aware applications suitable to a ubiquitous Internet.
Autre [cs.OH]
RR-5025.pdf (469.78 Ko) Télécharger le fichier
inria-00071559 , version 1 (23-05-2006)
  • HAL Id : inria-00071559 , version 1
Eric Fleury, Stéphane Frénot. Building a JMX management interface inside OSGi. RR-5025, INRIA. 2003. ⟨inria-00071559⟩
84 Consultations
690 Téléchargements
