Heterogeneous Reactive Systems Modeling and Correct-by-Construction Deployment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We propose a mathematical framework to deal with the composition of heterogeneous reactive systems. Our theory allows to establish theorems, from which design techniques can be derived. We illustrate this by two cases: the deployment of synchronous designs over architectures, and the deployment of synchronous designs over the so-called Loosely Time-Triggered Architectures. This report is an extended version of a paper with same title that appeared in the Proc. of EMSOFT'2003. This report appeared also as a technical report from the University of California at Berkeley, number UCB/ERL M03/23.
RR-4901.pdf (327.19 Ko) Télécharger le fichier
inria-00071682 , version 1 (23-05-2006)
  • HAL Id : inria-00071682 , version 1
Albert Benveniste, Luca P. Carloni, Paul Caspi, Alberto Sangiovanni-Vincentelli. Heterogeneous Reactive Systems Modeling and Correct-by-Construction Deployment. [Research Report] RR-4901, INRIA. 2003. ⟨inria-00071682⟩
138 Consultations
232 Téléchargements
