A relative compactness criterion in Wiener-Sobolev spaces and application to semi-linear Stochastic P.D.Es - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Vlad Bally
  • Fonction : Auteur
Bruno Saussereau
  • Fonction : Auteur
We prove a relative compactness criterion in Wiener-Sobolev space which represents a natural extension of the compact embedding of sobolev space H^1 into L^2, at the level of random fields. Then we give a specific statement of this criterion for random fields solutions of semi-linear Stochastic Partial Differential Equations with coefficients bounded in an appropriate way. Finally, we employ this result to construct solutions for semi-linear Stochastic Partial Differential Equations with distribution as final condition. We also give a probabilistic interpretation of this solution in terms of Backward Doubly Stochastic Differential Equations formulated in a weak sense.
RR-4805.pdf (455.16 Ko) Télécharger le fichier
inria-00071781 , version 1 (23-05-2006)
  • HAL Id : inria-00071781 , version 1
Vlad Bally, Bruno Saussereau. A relative compactness criterion in Wiener-Sobolev spaces and application to semi-linear Stochastic P.D.Es. [Research Report] RR-4805, INRIA. 2003. ⟨inria-00071781⟩
109 Consultations
237 Téléchargements
