Dealing with Heterogeneity in an Active-based Multicast Congestion Avoidance Protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Cong-Duc Pham
Many of the proposed multicast congestion avoidance algorithms are single-rate where heterogeneity is accommodated by adjusting the transmission rate as a response to the worst receiver in the group. Due to the Internet heterogeneity, a single-rate congestion control affects the overall satisfaction of a multicast session receivers. In this report, we propose a multi-rate replicated scheme where some receivers (instead of the source) are designated to perform data replication for other receivers with lower capacity. To be more scalable and to minimize the bandwidth consumption due to data replication, the partitioning algorithm is performed on-the-fly by the routers depending on the feedbacks they receive. Neither a prior estimation of the receivers capacity is necessary nor a complex computation is required to execute our partitioning algorithm.
Autre [cs.OH]
RR-4796.pdf (495.34 Ko) Télécharger le fichier
inria-00071790 , version 1 (23-05-2006)
  • HAL Id : inria-00071790 , version 1
Moufida Maimour, Cong-Duc Pham. Dealing with Heterogeneity in an Active-based Multicast Congestion Avoidance Protocol. RR-4796, INRIA. 2003. ⟨inria-00071790⟩
83 Consultations
95 Téléchargements
