Distributed Process Networks Using Half FIFO Queues in CORBA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Process networks are networks of sequential processes connected by channels behaving like FIFO queues. These are used in signal and image processing applications that need to run in bounded memory for infinitely long periods of time dealing with possibly infinite streams of data. This paper is about a distributed implementation of this computation model. We present the implementation of a distributed process network by using distributed FIFOs to build the distributed application. The platform used to support this is the CORBA middleware.
Autre [cs.OH]
RR-4765.pdf (149.45 Ko) Télécharger le fichier
inria-00071821 , version 1 (23-05-2006)
  • HAL Id : inria-00071821 , version 1
Abdelkader Amar, Pierre Boulet, Jean-Luc Dekeyser, Frans Theeuwen. Distributed Process Networks Using Half FIFO Queues in CORBA. [Research Report] RR-4765, INRIA. 2003. ⟨inria-00071821⟩
161 Consultations
271 Téléchargements
