Perturbations and Vertex Removal in a 3D Delaunay Triangulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Olivier Devillers
Monique Teillaud
Though Delaunay triangulations are very well known geometric data structures, the problem of the robust removal of a vertex in a three-dimensional Delaunay triangulation is still a problem in practice. We propose a simple method that allows to remove any vertex even when the points are in very degenerate configurations. The solution is available in \cgal\footnote{\texttt- {http://www.cgal.org} (releases 2.3 and 2.4)}.
Autre [cs.OH]
RR-4624.pdf (239.98 Ko) Télécharger le fichier
inria-00071961 , version 1 (23-05-2006)
  • HAL Id : inria-00071961 , version 1
Olivier Devillers, Monique Teillaud. Perturbations and Vertex Removal in a 3D Delaunay Triangulation. RR-4624, INRIA. 2002. ⟨inria-00071961⟩
109 Consultations
182 Téléchargements
