Incremental Concept Formation made More Efficient by the Use of Associative Concepts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Sébastien Ferré
Formal Concept Analysis (FCA) is interested in the formation of concept lattices from binary relations between objects and attributes, a.k.a. contexts. Many algorithms have been proposed to generate the set of all concepts, and also the edges of the lattice between these concepts. We develop the principle and the code of a new algorithm combining two existing ones, Godin's and Bordat's algorithms. Then, we show by both a theoretical and practical study that it is the most efficient algorithm for sparse contexts, which are usually found in real applications.
Autre [cs.OH]
RR-4569.pdf (247.26 Ko) Télécharger le fichier
inria-00072019 , version 1 (23-05-2006)
  • HAL Id : inria-00072019 , version 1
Sébastien Ferré. Incremental Concept Formation made More Efficient by the Use of Associative Concepts. [Research Report] RR-4569, INRIA. 2002. ⟨inria-00072019⟩
137 Consultations
108 Téléchargements
