GC^2: A Generational Conservative Garbage Collector for the ATerm Library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
The ATerm library is a well-designed and well-known library in the term rewriting community. In this paper, we discuss the current garbage collector provided with the library and stress the fact that some peculiarities of this functional library could be taken advantage of by the memory management system. We explain how we designed and implemented GC², a new mark-and-sweep generational garbage collector for the ATerm library that builds upon these peculiarities. Experimental results on various programs validate our approach, and show that the performance of our new algorithm is very good.
Autre [cs.OH]
RR-4548.pdf (357.9 Ko) Télécharger le fichier
inria-00072040 , version 1 (23-05-2006)
  • HAL Id : inria-00072040 , version 1
Pierre-Etienne Moreau, Olivier Zendra. GC^2: A Generational Conservative Garbage Collector for the ATerm Library. [Research Report] RR-4548, INRIA. 2002, pp.28. ⟨inria-00072040⟩
165 Consultations
255 Téléchargements
