Multicast routing with bandwidth requirement in the case of incomplete information as a Steiner tree problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
This paper is concerned with developing novel algorithms for multicast routing in packet switched communication networks. First, multicast routing with bandwidth requirement in the case of incomplete information is reduced to a deterministic Steiner tree problem. Then taboo search algorithms are used to provide high quality, sub-optimal solutions for multicast routing in polynomial time.
Autre [cs.OH]
RR-4343.pdf (666.84 Ko) Télécharger le fichier
inria-00072245 , version 1 (23-05-2006)
  • HAL Id : inria-00072245 , version 1
Patrice Leguesdron, János Levendovszky, Miklos Molnar, Csaba Végsö. Multicast routing with bandwidth requirement in the case of incomplete information as a Steiner tree problem. [Research Report] RR-4343, INRIA. 2001. ⟨inria-00072245⟩
298 Consultations
109 Téléchargements
