Numerical Reliability and CPU Time for the Mixed Methods applied to Flow Problems in Porous Media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
This work is devoted to the numerical reliability and time requirements of the Mixed Finite Element (MFE) and Mixed-Hybrid Finite Element (MHFE) methods. The behavior of these methods is investigated under the influence of two factors: the mesh discretization and the medium heterogeneity. We show that, unlike the MFE, the MHFE "suffers" with the presence of flatted triangular elements. A numerical reliability analyzing software (Aquarels) is used to detect the instability of the matrix-inversion code generated by MAPLE which is used in the MHFE code. We also show that the spectral condition number of the algebraic systems furnished by both methods in heterogeneous media grows up linearly according to the smoothness of the hydraulic conductivity. Furthermore, it is found that the MHFE could accumulate numerical errors if the conductivity varies abruptly in space. Finally, we compare running-times for both algorithms by giving various numerical experiments.
RR-4228.pdf (614.11 Ko) Télécharger le fichier
inria-00072391 , version 1 (24-05-2006)
  • HAL Id : inria-00072391 , version 1
Hussein Hoteit, Jocelyne Erhel, Robert Mosé, Bernard Philippe, Philippe Ackerer. Numerical Reliability and CPU Time for the Mixed Methods applied to Flow Problems in Porous Media. [Research Report] RR-4228, INRIA. 2001. ⟨inria-00072391⟩
207 Consultations
76 Téléchargements
