Bossa: A DSL Framework for Application-specific Scheduling Policies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Developing or specializing existing process schedulers for new needs is tedious and error-prone due to the lack of modularity and inherent complexity of scheduling mechanisms. In this paper, we propose a framework based on a Domain-Specific Language for the implementation of scheduling policies. This framework permits the installation of basic scheduling policies, called Virtual Schedulers, and the development of Application-Specific Policies, which tailor a Virtual Scheduler to application-specific requirement- s. We illustrate our approach with concrete examples that show how specializat- ion and reuse of scheduling policies can be accomplished while retaining OS robustness.
Autre [cs.OH]
RR-4191.pdf (214.17 Ko) Télécharger le fichier
inria-00072431 , version 1 (24-05-2006)
  • HAL Id : inria-00072431 , version 1
Luciano Porto Barreto, Gilles Muller. Bossa: A DSL Framework for Application-specific Scheduling Policies. [Research Report] RR-4191, INRIA. 2001. ⟨inria-00072431⟩
184 Consultations
450 Téléchargements
