A Work-Optimal Algorithm on log delta n Processors for a P-Complete Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Jan Arne Telle
  • Fonction : Auteur
  • PersonId : 889063
We present a parallel algorithm for the Lexicographically First Maximal Independent Set Problem on graphs with bounded degree 3 that is work-optimal on a shared memory machine with up to $\log ^\delta n$ processors, for any $0 < \delta < 1$. Since this problem is P-complete it follows (assuming $\mathcalNC \not \mathcalP$) that the algorithmics of coarse grained parallel machines and of fine grained parallel machines differ substantially.
Autre [cs.OH]
RR-4174.pdf (154.18 Ko) Télécharger le fichier
inria-00072448 , version 1 (24-05-2006)
  • HAL Id : inria-00072448 , version 1
Jens Gustedt, Jan Arne Telle. A Work-Optimal Algorithm on log delta n Processors for a P-Complete Problem. [Research Report] RR-4174, INRIA. 2001, pp.9. ⟨inria-00072448⟩
71 Consultations
333 Téléchargements
