Solution of Non-Linear Elasticity Problems Using the Continu Software - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
A general Newton method with arc-length continuation was implemented in the software continu. This paper recalls the main principle of the method and describes how to use and modify the software to make it possible to solve a large variety of non-linear problems for hyper-elastic materials. Several three-dimensional finite elements are available.
RR-4128.pdf (480.65 Ko) Télécharger le fichier
inria-00072500 , version 1 (24-05-2006)
  • HAL Id : inria-00072500 , version 1
Marina Vidrascu. Solution of Non-Linear Elasticity Problems Using the Continu Software. [Research Report] RR-4128, INRIA. 2001. ⟨inria-00072500⟩
102 Consultations
172 Téléchargements
