Abstract : We address the problem of non-parametric multi-modal image matching. We propose a generic framework which relies on a global variational formulation and show its versatility through three different multi-modal registration methods : supervised registration by joint intensity learning, maximization of the mutual information and maximization of the correlation ratio. Regulariz- ation is performed by using a functional borrowed from linear elasticity theory. We also consider a geometry-driven regularization method. Experiments on synthetic images and preliminary results on the realignment of MRI datasets are presented.
