Reports
Implementing a Variant of the Kanatani's Estimation Method
Thierry Viéville 1 Diane Lingrand 1 François Gaspard 1
1 ROBOTVIS - Computer Vision and Robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : We revisit the problem of parameter estimation in computer vision, reconsideri- ng and implementing what may be called the Kanatani's estimation reconsidering and implementing what may be called the Kanatani's estimation method, presented here as a simple optimisation problem, so (a) without any method, presented here as a simple optimisation problem, so (a) without any direct reference to a probabilistic framework but (b) considering (i) direct reference to a probabilistic framework but (b) considering (i) non-linear implicit measurement equations and parameter constraints, plus non-linear implicit measurement equations and parameter constraints, plus (ii) robust estimation in the presence of outliers and (iii) multi-model (ii) robust estimation in the presence of outliers and (iii) multi-model comparisons. comparisons. Here, (A) a projection algorithm based on generalisations of square-root Here, (A) a projection algorithm based on generalisations of square-root decompositions allows an efficient and numerically stable local resolution decompositions allows an efficient and numerically stable local resolution of a set of non-linear equations. On the other hand, (B) a robust estimation of a set of non-linear equations. On the other hand, (B) a robust estimation module of a hierarchy of non-linear models has been designed and validated. module of a hierarchy of non-linear models has been designed and validated. A step ahead, (C) the software architecture of the estimation module is A step ahead, (C) the software architecture of the estimation module is discussed with the goal of being integrated in reactive software discussed with the goal of being integrated in reactive software environments or within applications with time constraints, while an environments or within applications with time constraints, while an experimentation considering the parameterisation of retinal displacements experimentation considering the parameterisation of retinal displacements between two views is proposed as an illustration of the estimation module.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072587
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 10:20:59 AM
Last modification on : Friday, February 4, 2022 - 3:08:53 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:15:21 PM
Identifiers
  • HAL Id : inria-00072587, version 1
Collections
Citation
Thierry Viéville, Diane Lingrand, François Gaspard. Implementing a Variant of the Kanatani's Estimation Method. [Research Report] RR-4050, INRIA. 2000. ⟨inria-00072587⟩
Share
Metrics
Record views
57
Files downloads
109
