From Rounding Error Estimation to Automatic Correction with Automatic Differentiation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2000
Philippe Langlois
Using automatic differentiation (AD) to estimate the propagation of rounding errors in numerical algorithms is classic. We propose a new application of AD to roundoff analysis providing an automatic correction of the first order effect of the elementary rounding errors. We present the main characteri- stics of this method and significant examples of its application to improve the accuracy of computed results and/or the stability of the algorithm.
RR-3967.pdf (227 Ko) Télécharger le fichier
inria-00072681 , version 1 (24-05-2006)
  • HAL Id : inria-00072681 , version 1
Philippe Langlois. From Rounding Error Estimation to Automatic Correction with Automatic Differentiation. RR-3967, INRIA. 2000. ⟨inria-00072681⟩
81 Consultations
858 Téléchargements
