A Fully Discrete Approximation for Control Problems governed by Parabolic Variational Inequalities - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2000
, (1)
1
In this work we consider a numerical approximation of an optimal control problem governed by variational inequalities. We use a total discretization scheme: implicit Euler discretization with respect to the time variable and finite element method for the space variable, and give convergence results.
RR-3940.pdf (334.46 Ko) Télécharger le fichier
Dates and versions
inria-00072710 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00072710 , version 1
Cite
Martine Bergounioux, Hasnaa Zidani. A Fully Discrete Approximation for Control Problems governed by Parabolic Variational Inequalities. [Research Report] RR-3940, INRIA. 2000. ⟨inria-00072710⟩
50 View
174 Download
Share
