HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Analysis of a Priority Stack Random Access Protocol In W-CDMA Systems
Khaldoun Al Agha 1 Philippe Jacquet 1 Nikita Vvedenskay
1 HIPERCOM - High performance communication
Inria Paris-Rocquencourt, UP11 - Université Paris-Sud - Paris 11, Inria Saclay - Ile de France, X - École polytechnique, CNRS - Centre National de la Recherche Scientifique : UMR
Abstract : The stack protocol (called also tree protocol) can be used in order to introduce a priority mechanism on the random access stage in W-CDMA. Indeed, after second generation networks supporting voice service only, the third generation systems (UMTS) should offer more services with quality and priority. However, all priorities in the UMTS system are based on the dedicated channel and after the random access mechanism that use the weak access protocol: slotted aloha. In this paper, we analyze the possibility to apply the tree random access protocol for the W-CDMA part in the UTRA radio interface proposition. We study also a priority system applied on the random access directly. The analytical model use generating functions and an algebraic method in order to show the stack protocol performance. Also, numerical and simulation results are presented and show the predominance of this protocol compared with the slotted aloha mechanism.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072730
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 10:43:02 AM
Last modification on : Friday, February 4, 2022 - 3:13:49 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:19:57 PM
Identifiers
  • HAL Id : inria-00072730, version 1
Collections
Citation
Khaldoun Al Agha, Philippe Jacquet, Nikita Vvedenskay. Analysis of a Priority Stack Random Access Protocol In W-CDMA Systems. [Research Report] RR-3922, INRIA. 2000. ⟨inria-00072730⟩
Share
Metrics
Record views
147
Files downloads
263
