Introduction to the Rewriting Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
The $\rho$-calculus is a new calculus that integrates in a uniform and simple setting first-order rewriting, $\lambda$-calculus and non-deterministic computations. This paper describes the calculus from its syntax to its basic properties in the untyped case. We show how it embeds first-order conditional rewriting and $\lambda$-calculus. Finally we use the $\rho$-calcul- us to give an operational semantics to the rewrite based language ELAN.
Autre [cs.OH]
RR-3818.pdf (501.6 Ko) Télécharger le fichier
inria-00072840 , version 1 (24-05-2006)
  • HAL Id : inria-00072840 , version 1
Horatiu Cirstea, Claude Kirchner. Introduction to the Rewriting Calculus. [Research Report] RR-3818, INRIA. 1999, pp.50. ⟨inria-00072840⟩
156 Consultations
353 Téléchargements
