Algorithm, Proof and Performances of a new Division of Floating Point Expansions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
Marc Daumas
  • Fonction : Auteur
Claire Finot
  • Fonction : Auteur
We present in this work a new algorithm for the division of floating point expansions. Floating expansion is a multiple precision data type developped with arithmetic operators that use the processor floating point unit for core computations instead of the integer unit. Researches on this subject have arised recently from the observation that the floating point unit becomes a more and more efficient part of modern computers. Many simple arithmetic operators and some very usefull geometric operators have already been presented on expansions. Yet previous work presented only a very simple division algorithm. We present in this work a new algorithm. We take this opportunity to extend the set of geometric operators with Bareiss' determinant on a matrix of size between 3 and 10. Running times with different determinant algorithms on different machines are compared with other multiprec- ision packages including GMP, CADNA and a computer geometry package working with modular arithmetic.
Autre [cs.OH]
RR-3771.pdf (281 Ko) Télécharger le fichier
inria-00072890 , version 1 (24-05-2006)
  • HAL Id : inria-00072890 , version 1
Marc Daumas, Claire Finot. Algorithm, Proof and Performances of a new Division of Floating Point Expansions. [Research Report] RR-3771, INRIA. 1999. ⟨inria-00072890⟩
102 Consultations
192 Téléchargements
