Semidefinite Relaxations and Lagrangian Duality with Application to Combinatorial Optimization - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1999
We show that it is fruitful to dualize the integrality constraints in a combinatorial optimization problem. First, this reproduces the known SDP relaxations of the max-cut and max-stable problems. Then we apply the approach to general combinatorial problems. We show that the resulting duality gap is smaller than with the classical Lagrangian relaxation; we also show that linear constraints need a special treatment.
RR-3710.pdf (376.13 Ko) Télécharger le fichier
Dates and versions
inria-00072958 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00072958 , version 1
Cite
Claude Lemaréchal, François Oustry. Semidefinite Relaxations and Lagrangian Duality with Application to Combinatorial Optimization. [Research Report] RR-3710, INRIA. 1999. ⟨inria-00072958⟩
635 View
500 Download
Share
