Using Viscosity Solution for Approximations in Piecewise Deterministic Control Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
Odile Pourtallier
Mabel M. Tidball
In [15] a numerical approximation scheme is proposed for the solution of piecewise deterministic control systems (PDCS). This approximation scheme is based on a time discretization which reformulates the original PDCS into a stochastic program. In this paper we prove the convergence of the approximating vector value function to the vector value function of the original PDCS as the discretization's step tends to zero.
RR-3687.pdf (272.84 Ko) Télécharger le fichier
inria-00072982 , version 1 (24-05-2006)
  • HAL Id : inria-00072982 , version 1
Francesco Moresino, Odile Pourtallier, Mabel M. Tidball. Using Viscosity Solution for Approximations in Piecewise Deterministic Control Systems. RR-3687, INRIA. 1999. ⟨inria-00072982⟩
48 Consultations
104 Téléchargements
