Using Parallel Computing to Reduce CPU Power
Jérôme Galtier 1
1 SLOOP - Simulation, Object Oriented Languages and Parallelism
CRISAM - Inria Sophia Antipolis - Méditerranée , COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : In this paper, we analyze parallelism as an energy-saving technique for mobile terminal or on-board systems. We show that the expected gains are considerable. However, some natural constraints can appear when applying massively this idea. Therefore, we analyze this concept on a simple model in an environment where either the space for circuitry is restricted, or the total weight of the system, including energy sources, has to be minimized. It turns to give new types of CAD problems. Finally, we analyze fault tolerance issues and solutions in a satellite-like environment.
Type de document :
Rapport
RR-3621, INRIA. 1999
Liste complète des métadonnées
https://hal.inria.fr/inria-00073056
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 11:43:04
Dernière modification le : mercredi 31 janvier 2018 - 10:24:04
Document(s) archivé(s) le : dimanche 4 avril 2010 - 23:32:58
Fichiers
  • HAL Id : inria-00073056, version 1
Collections
Citation
Jérôme Galtier. Using Parallel Computing to Reduce CPU Power. RR-3621, INRIA. 1999. 〈inria-00073056〉
Métriques
Consultations de la notice
149
Téléchargements de fichiers
270
