Reports
On the Stability of a Bandwidth Packing Algorithm
Abstract : The stability properties of the bandwidth allocation algorithm First Fit are analyzed for some distributions on the sizes of the requests. Fluid limits are used to get the ergodicity results. When there are two possible sizes, the description of the transient behavior involves a finite Markov chain on the exit states of a transient Markov chain on a countable state space. The explicit expression of this exit matrix is given.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00073075
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 11:47:25 AM
Last modification on : Thursday, February 3, 2022 - 11:18:32 AM
Long-term archiving on: : Sunday, April 4, 2010 - 8:57:45 PM
Identifiers
  • HAL Id : inria-00073075, version 1
Collections
Citation
Jean-François Dantzer, Mostafa Haddani, Philippe Robert. On the Stability of a Bandwidth Packing Algorithm. [Research Report] RR-3605, INRIA. 1999. ⟨inria-00073075⟩
Share
Metrics
Record views
56
Files downloads
145
