Abstract : In this report, we present a new method of aligning histological sections. First a displacement field between the two images is computed by block matching. Then we estimate a rigid transformation based on the field. The process is integrated within a multi-scale scheme. We carefully study the problem of robustness and we propose several ideas to deal with inter-sect- ion intensity differences and background artifacts. We demonstrate experimenta- lly that we can reach a sub-voxel accuracy and we show some results on histological sections of a rat's brain and an endometrical adenocarcinoma.
https://hal.inria.fr/inria-00073084 Contributor : Rapport de Recherche InriaConnect in order to contact the contributor Submitted on : Wednesday, May 24, 2006 - 11:49:10 AM Last modification on : Friday, February 4, 2022 - 3:14:40 AM Long-term archiving on: : Sunday, April 4, 2010 - 9:16:48 PM
